Old 02-14-2013, 07:54 AM   #1
Larry Hausch
Default Wheels/Tires/350Trans/Gears and More
15x14 Weld AlumiStars 4"BS (Used) $400.00
15x12 Weld Magnum Pro 3"BS (Used) $400.00
15x4 Weld Magnum Pro w/7.10x15 Moroso Drag Special Tires (Used) $550.00
15x4 Weld AlumiStar 2.0 w/26 4.5x15 FrontRunners (New/Mounted/Never Run) $800.00
Rossler 350 Stocker Trans 2.75 Low Gear Aluminum Drum Deep Pan $1100.00
RacePak SC1000 Complete includes 8EGT's $500 .00
Richmond ProGears Ford 9" 31-5 6.20 Ratio $275.00
Simpson Black 10Ft. Parachute (New) $275.00
Also have Hotchkis Upper and Lower Control Arms, Flomaster Merge Collectors and Hooker Headers and 2-QJet Carbs for Oldsmobile
Larry Hausch
Larry_Hausch@yahoo.com
330-606-0361 cell/voicemail
Larry Hausch is offline   Reply With Quote
Old 02-15-2013, 09:18 AM   #2
Mike Walter
Liked 46 Times in 4 Posts
Default Re: Wheels/Tires/350Trans/Gears and More
Larry, you have a PM.
Mike Walter is offline   Reply With Quote
