Old 02-12-2013, 11:34 AM   #1
Jim Hanig
Liked 99 Times in 49 Posts
Default Moving sale
1 Mallory red coil 25.00 1 280 barry grant 100.00 1 set 041 stock untouched heads 100.00 1 set 041 headsangle milled to 53 cc 100.00 1 283 steel crank stroked .012 200.00 1 283 ss old school motor less balancer,pan rockers 1500.00 1 402 375 dynoed time iron heads like new cp piston rods crank cam smith lifters ati balancer billet chain aluim tim cover csr water pump and more 5000.00 1 402 sleeved 454 blk lifter bushed diamond honed to 4.185 350 what it cost to have it honed.1 set 520 unwelded ss heads flowed in 220cfm new manley valves no springs 500.00 new moroso vac pump 300.00 1 780 stocker prc carb 600.00 1 800 holley 250.00 1 18 ported intake 100.00 1 new 356 intake 300.00 1 396 stocker intake 50.00 1 hurst PG shifter 60.00 1 woodro lt1 stocker cam 50.00 1 390 410 Bullet cam 125.00 1 set MT df pro drag radials 101 roll out 125.001 c4 289 TCI convertor 6400 stall 200.00 1 set 184 ex valves new 100.00 1 218 low pg with shield and brake. 900.00 1 set cp 350 ss piston with small intake relief 450.00 1 srt koni ft shocks, camaro, nova, 100.001 182 Small bore bowtie blk 50mm roller bearings 4inch now 1000.oo all plus frght. Jim Hanig
Old 02-12-2013, 11:53 AM   #2
DarrellCiaravino
Liked 39 Times in 3 Posts
Default Re: Moving sale
I would like to buy some parts you have listed. call me (734)558-3295 Thanks, Darrell
DarrellCiaravino is offline   Reply With Quote
Old 02-12-2013, 01:05 PM   #3
Robert Simpson
Liked 20 Times in 12 Posts
Jim PM sent
Robert Simpson is offline   Reply With Quote
Old 02-14-2013, 10:13 AM   #4
Jim Hanig
P,M me i will give what ever info you need Jim
Old 02-14-2013, 11:06 AM   #5
DarrellCiaravino
Thanks anyway, Darrell (734)558-3295!!!!!!!!!!!
