Old 02-12-2013, 10:20 AM   #1
Ian Hill
Ian Hill's Avatar
Liked 6 Times in 3 Posts
Default Msd rpm selector switch
I have installed the rpm selctor switch 8670 in my stocker and use it instead of the 2 step individual pills as i have recently been racing at a dtrip that have the first two passes of the night in the day light and the rest at night, so i find myself adjusting the rpm of the launch to compensate for the night time brightness of the tree.
The module (8670) comes with about a 4 inch connector cable, my question is: can i cut these wires and extend them? i'd like to have this module mounted at my shifter where i can make changes as i am about to make my run, rather than sitting in the staging lanes, strapped in and not able to reach it.
Ian
They say money can't buy happiness, it can buy race car parts, and that makes me happy
Ian Hill
GT/FA 1982 Camaro, F/CM 1968 Camaro
Ian Hill is offline   Reply With Quote
Old 02-12-2013, 10:30 AM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Msd rpm selector switch
That's what I use. I can't imagine why the wires couldn't be extended.
Ed Wright 4156 SS/JA
Old 02-12-2013, 10:43 AM   #3
KRatcliff
Liked 534 Times in 143 Posts
Ian
General Regs 8:2 "Two-steps or other rev limiters that are
adjustable by thumbwheel, replaceable chips, and the like may not
be within the driver’s reach and will preferably be located outside
the driver compartment."
KRatcliff is offline   Reply With Quote
Old 02-12-2013, 10:44 AM   #4
acme383
the same cable MSD sells for the ignition box crank/ distributor is the same 2 pin cable. just an option if you don't want to cut it. Dan
acme383 is offline   Reply With Quote
Old 02-12-2013, 10:47 AM   #5
Bill Harris
Liked 26 Times in 13 Posts
The RPM "pills" for the analog MSD boxes are just resistors and are relatively high values compared to the wiring. For example, a 4K pill is 2700 ohms while a 7K pill is 5660 ohms, nominally. Extending the wires won't add enough resistance to vary the set-points unless you use tiny gauge wire and/or make really bad connections.
One thing you should think about, though, is that "pill" is in a pretty high impedance circuit, so it is susceptible to electrical noise which could make the set-point jump around. If you do extend the wires, I would use a shielded cable with two conductors, perhaps an 18 gauge shielded speaker cable (foil shield is best) and ground the shield at the box end only.
Bill Harris
ex 2172 STK
ex 2272 S/S
Bill Harris is offline   Reply With Quote
Old 02-12-2013, 12:42 PM   #6
Ian Hill
Ian Hill's Avatar
ahhhh, read the rules, seems like as good an answer as any!
Ian
Ian Hill
Old 02-12-2013, 01:31 PM   #7
69Cobra
Liked 2 Times in 2 Posts
What's the reason for this? Shouldn't the driver have compete control over the car, rev limiters included.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 02-12-2013, 02:02 PM   #8
KRatcliff
I don't know the reason. I just remembered the rule because I wanted to do exactly the same thing the original poster wants to do, but I had read that you couldn't in the rule book.
Old 02-12-2013, 02:09 PM   #9
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
MSD #8735 features a shielded cable for that purpose and I have seen it in use in Stockers......planned to use one in mine. It's a 3-step selector featuring burnout & high end chips plus adjustable launch rpm.
Dave Turner
SS/GT #1153
Old 02-12-2013, 03:42 PM   #10
Ian Hill
Ian Hill's Avatar
hi Dave, is it something you planned on placing within your reach as a driver?
Ian Hill
