Old 02-10-2013, 05:51 PM   #1
rod
Liked 20 Times in 15 Posts
Default SBC 4" head gasket ?
I am working on this 327 + 60 which for the time will be a bracket engine. [it will be a 350 Horse 327 which hopefully will go in a '65 Chevelle 300 2 dr.]
anyway, this engine will go 60 over. the cheap blue Fel-Pro gaskets go right to the edge of a 30 over cylinder now. i checked several other brands, Mr. G, old Fel-Pro, Rocket, and they all look the same. even a used 400 gasket comes close.
So my ? is how close is too close and also the reverse, how big a gasket bore is too big?
Thanks Rod in AZ
rod is offline   Reply With Quote
Old 02-10-2013, 07:35 PM   #2
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: SBC 4" head gasket ?
Rod there are many 4.060 gaskets , UNless the chamfer at the top of the block is extra large the 4.100 GM gasket should work,I try to keep the gasket bore as tight as i can. I would not have any more than .060 bigger. Stockers need all the comp they can get. Jim
Old 02-10-2013, 07:54 PM   #3
james schaechter
Liked 1,436 Times in 299 Posts
Thanks Rod in AZ
I use Cometic gaskets on our engines. They can be ordered to thickness and bore size. I re use them a few times without any problems.
We have 327 350 hp among others in our 66 Nova stocker
James Schaechter 3163 STK
Old 02-11-2013, 10:47 AM   #4
carl hinkson
Liked 18 Times in 10 Posts
If your using a performance gasket those blocks sometimes require an extra hole drilled in deck. This link applies to all SBC' if using a a peformance gasket.
http://www.chevyhiperformance.com/te...cks/index.html
carl hinkson is offline   Reply With Quote
