Old 02-09-2013, 11:51 PM   #1
Chad Mahlosky
Liked 7 Times in 2 Posts
Default Brake pressure switch
I know that there's a few older posts about this, but what are you guys using for a pressure switch to two-step a stocker? I haven't tried it since they did away with the button in stock, but I am redoing my lines this winter and thought I would install one. I hate to give a ton of money for one like the folk switch, when I'm not sure if I will stick with it, or just continue to footbrake. Any info is appreciated!
Chad Mahlosky 3225 STK
Chad Mahlosky is offline   Reply With Quote
Old 02-10-2013, 10:26 AM   #2
Liked 10,820 Times in 2,249 Posts
Default Re: Brake pressure switch
Gary Jennings race cars has a very good one that is adjustable. I really like it. 615-754-9381
Old 02-10-2013, 12:09 PM   #3
Mike Delahanty
Mike Delahanty's Avatar
Liked 276 Times in 54 Posts
Tranducers Direct. Adjustable pressure switch. PN TDPS83CW.
This is the link. http://www.transducersdirect.com/Hel...d%2bXI8A%3d%3d
You can order online.
Old 02-10-2013, 01:28 PM   #4
Mile High
I've run my car like this since 96 and have used a stock Ford pressure switch. When I went to disc brakes on the front and updated the master cylinder the switch screwed right into a port on my line lock. Add a gage if you need to but I adjust my settings with the tire pressures. It's cheap too.
http://www.autozone.com/autozone/par...mString=search
Jeff
Street legal 64 Falcon Sprint with 410W living in Texas.
Stock - Super Stock fan
Mile High is offline   Reply With Quote
Old 02-11-2013, 09:11 AM   #5
Chad Mahlosky
Thank you guys for the information, very helpful as always!
