Old 02-02-2013, 07:50 PM   #1
ruthlessracing
Default sb ford roller cams,rockers,lifters, jesel,heads
USED COMP PRO MAGUM 1.6X3/8 WITH LOCKS $175. THEY ARE IN GOOD CONDITION SHIPPED
USED SB FORD TRICK FLOW TWISTED WEDGE R HEADS. 206CC INTAKE RUNNERS,2.08/160 VALVES, 720 LIFT SOLID ROLLER SPRINGS,61CC CHAMBERS.THESE HEADS ARE LIKE NEW WITH DYNO TIME. THEY WERE ABOUT $2000 WITH SOLID ROLLER SPRINGS, SELLING $1650 SHIPPED, OR TRADE FOR 79 PACE CAR,80-81COBRA OR 82 GT
USED SB FORD ROLLER BEARINGS COMP CAM SOLID ROLLER CAM HAS TH, , LIFT IS .867 INTAKE AND .791 WITH A 1.7 ROCKER, EXHAUST, DURATION AT .050 IS 288 / 278 DEGREES, LOBE SEPERATION IS 110 DEGREES $250
NEW ROLLER BEARINGS COMP CAM SOLID ROLLER CAM, , LIFT IS ..768 INTAKE AND .707 WITH A 1.6 ROCKER, EXHAUST, DURATION AT .050 IS 287 / 300 DEGREES, LOBE SEPERATION IS 114 $325
USED COMP CAMS ROLLER BEARINGS .726 INTAKE AND .693 WITH A 1.65 RATION ROCKER, EXHAUST, DURATION AT .050 IS 250 / 272DEGREES, LOBE SEPERATION IS 112 DEGREES, $250 SHIPPED
USED COMP CAMS ROLLER BEARINGS LIFT IS .704INTAKE AND .672 WITH A 1.6 ROCKER, EXHAUST, DURATION AT .050 IS 254 / 272 DEGREES, LOBE SEPERATION IS 112 DEGREES $250 SHIPPED
USED GT40 351W LOWER INTAKE $400 SHIPPED
USED COMP CAMS SOLID ROLLER LIFTER $250 SHIPPED
USED CROWER HIPO ROLLER LIFTERS $ 375 SHIPPED
USED CRANE PRO SOLID ROLLER LIFTERS $375
FORD C4 26 SPLINE. ROLLER DRUM,REAR PLANET GEARS &HUB .ALL THE PARTS HAVE BEEN SET UP FOR ROLLER BEARNINGS. THE ONLY USED PART IS THE REAR HUB BUT IT HAS NEW ROLLER BEARNING $175 SHIPPED
USED SB FORD JESEL1.6 SPORTSMAN SHAFT ROCKERS. THEY FIT STD VALVE LAY OUT HEADS $750 SHIPPED
UseD jesel 1.6 n351 heads. These are the full race ones not the cheaper sportmans. Dyno time ,new they were $1500,selling $925 shiipped
used sb ford belt drive $700 shipped
ruthlessracing is offline   Reply With Quote
