Old 01-30-2013, 09:13 PM   #1
Greg Reimer 7376
Liked 719 Times in 220 Posts
Question SBC Dart block question---?
Gotta question on a Dart block-the NHRA legal replacement legal in Stock. I had all the machine work done at Tri City in Vista,(a stellular enterprise if there ever was one,thanks Gregg),installed the cam, assembled the short block, and the cam lobes don't line up with the lifter bores with the chain set I used. It's the same chain set for a factory 327 or 350 block of that age. Does the Dart block require a different roller chain set, also I noticed provisions for a front thrust plate for the OEM later steel roller cams. Is there a later chain set with a different offset or something that would make this work? Just thought I'd ask.
Old 01-30-2013, 09:24 PM   #2
randy wilson
Liked 22 Times in 22 Posts
Default Re: SBC Dart block question---?
No, shim behind, or in front of the gear, and push it in, or out, whichever is needed. There is no special gear. There are shims from different type drives that will work.
don,t have one
Old 02-11-2013, 11:12 AM   #3
carl hinkson
Liked 18 Times in 10 Posts
If its a roller cam it should be centered a flat tappet cam some times is located to the rear of the bore.
carl hinkson is offline   Reply With Quote
Old 02-12-2013, 12:40 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
A easy way to check is look @ the chain w/ cam gear against block and see if it is in line w/crank gear,you may have to remove the chain and lay a straight edge across cam/crank gears,if it is out of line you will most likely break the chain pretty quick if is enough out of line it can have lifters hit sides of next cam lobe.
if is outta line have find where problem is and correct it
Mike Taylor 3601
