Old 01-24-2013, 09:28 PM   #1
Notch1320
Default FS: 87-93 Mustang 5.0 SBF Stocker Motor & Engine Management
311ci SBF Intake To Pan With Everything Below Included: $6000
.060 J&E Pistons With Coated Skirts (#141602)
.013 Offset Ground Crank (Polished)
ATI Super Dampner
ATI Timing Pointer
Eagle Rods
Coated Bearings
Ishiharra-Johnson Teflon Crank Scrapper
Canton Stock Eliminator Oil Pan
Melling Oil Pump
ARP Oil Pump Drive
ARP Bolts On Everything
Double Roller Timing Set
Custom Low Tension Rings From Greg Luneac & Chris Hardy @ RET ($470)
Bullet Billet Cam
Smith Brothers .080 Wall Pushrods
Roller Rockers From Alex @ Moneymaker Racing
Cliff Sherman Lifters
Manley Valves
Comp 999 Springs With Inner Removed
(RET) Chris Hardy Prepped E7 Heads http://www.racingenginetechnologies.com/
Kooks Stainless Step Headers, 1 5/8 x 1 3/4 x 3", w/ Spike Collectors
Ford Motorsport 24lbs Injectors
BBRC Aluminum Fuel Rails
CSR Elect. Water Pump
CSR Water Neck
CSR Billet Distributor Hold Down
Stock Distributor
Taylor Pro 409 Race Wires
HP Motorsports Solid Motor Mounts
Roush Alternator Mount & Crank Pulley
1 Wire Alternator
Stock Air Box Assembly With K&N Panel Filter
95 GT Starter
Engine was Freshened & Assembled By Daves Engine Machine
37530 Enterprise Court Newark, CA 94560
(510) 797-9536 (Angie & Dave)
Less than 50 passes @ K/S weight in a 88 Mustang Coupe, (215HP). 11.79 @ 111
Changing classes, so this needs to go!
I also have the Accel Engine Management System For Sale:
Accel GEN 7 DFI - $1100
For SBF (302) With Harness & All Sensors
Accel Single Channel Data Logger
Sportsman Key
Pro Key
Engine must sell bfeore the engine management system can go.
E-mail for questions @ Notch1320@yahoo.com
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
