Old 01-24-2013, 05:14 PM   #1
vic guilmino
Liked 56 Times in 21 Posts
Default need help again
my gen. 7500 will start and run for about 5 min. then stop and flash a 1 time then wait and then flash 1 time
HELP
Vic Guilmino 1129 STK
Old 01-24-2013, 05:27 PM   #2
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
Default Re: need help again
check the fuel filter,could be clogged, have ice??
Bob Lasko
Old 01-25-2013, 04:13 PM   #3
Matt Schurman
Sponsor
Hello Vic,.....
That ONE blink is telling you the machine is shut itself down in HI Engine Temp fault.
We've found that usually leads us to a few things:
1. Broken water pump belt, that will cause hi engine temp for sure.
2. Coolant loss or very low.
3. A build up of scale around the temp sensor, due to old coolant.
4. Bad sensor or control.
The covers need to come off to work on it. You might need to pull it from the coach depending on it's installation arrangement...
Matt Schurman
Matt Schurman is offline   Reply With Quote
