Old 01-19-2013, 11:35 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969-350-300HP Motor
1969 350-300HP motor casting number 3956618 dated A-4-9 on side and is stamped T0211HN and is a two bolt standard bore block. Heads 3927186 complete with rockers dated A-31-9 & B-7-9, intake 3927184 dated B-8-9, crankshaft 3932442 dated B-6-9. I have the original pistons and rods, camshaft, harmonic balancer, oil pan, dipstick and tube, oil pump, headbolts, pushrods, timing cover, timing chain, aftermarket edelbrock valve covers and fuel pump. Best offer on motor and is apart for inspection. I can ship if you cannot pick up. 330-770-2517 for any questions or pictures needed. All stock set up untouched.
dlv4540 is offline   Reply With Quote
