Old 01-18-2013, 04:56 PM   #1
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Default 8.5 x 20 ' Enclosed Trailer Question
Is there a down side of buying this size trailer ??
If it comes with 7,000 lb axles should that be all you need for the size of the trailer ???
Most of my races are within 2- 2.5 hours away.
Thx
"Pistol" Pete Dutko
Old 01-18-2013, 05:16 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: 8.5 x 20 ' Enclosed Trailer Question
Pete---buy the biggest longest trailer you can afford!!!!!!!!! ----it will never be big enough for all your stuff and when it comes time to sell it you will get more money for it than a shorter one-- YOU WILL NEVER REGRET IT---if you go ahead and buy a 20 sometime down the road you'll kick yourself in the *** saying why didnt I get that 24 footer it was only a coupla hundred dollars more!!!--think of building a garage why build a one car when if you build a 1 1/2 car you have just that much more room--- now if you build a 1 1/2 why not build a 2 car doesnt cost a lot more money but there is so much more you can do with it---
Old 01-18-2013, 10:21 PM   #3
Dave Turner
Dave Turner's Avatar
Liked 364 Times in 138 Posts
Unless you have a car under 16', I would give careful consideration to a 24 footer. From personal experience, I can tell you that if you plan to tote more than an air pig to the track, that 20' box fills up in a hurry. Go to a 26 if you have, or plan to acquire, some sort of pit vehicle.....good luck!!
Dave Turner
SS/GT #1153
Old 01-19-2013, 12:00 AM   #4
Run to Rund
Liked 54 Times in 27 Posts
I too took the advice of others and stepped up to a 24' box; you would be amazed how quickly it fills up. Regarding the 7000 lb axles, I bet they are 3500 lb each with 5 lug wheels. I recommend the 5000 lb axles with 6 lug wheels. It is too easy to overload one or both axles if they are 3500 or 3700 lb each. Also, with the torsion axles, remember that they should be evenly loaded since they can't distribute the load like leaf spring axles. The torsion axles do ride a lot better.
Old 01-19-2013, 10:36 AM   #5
Signman
Liked 269 Times in 99 Posts
NO 15 INCH WHEELS
Replacement tires are junk.
16 inch wheels at least.
You will not regret the heavier axles.
Old 01-19-2013, 11:36 AM   #6
FED 387
LOAD RANGE E or greater on those 16s
Old 01-19-2013, 12:40 PM   #7
FED 387
also STAY AWAY from any GOODYEAR trailer tires!!!!!
Old 01-19-2013, 01:03 PM   #8
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Not knowing you situation on how much room you have to park a trailer or what you have to pull one. Like is always stated " Buy as big as you can afford" You will not be sorry. Just be honest with yourself on what you have to pull it with as well. Get the biggest you can store and afford. Good luck.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 01-19-2013, 01:44 PM   #9
Pistol Pete
My original question is: Is 3500lb axles good enough on a 20' trailer.
I'm not worring about putting stuff in the trailer, other than a few items.
For the most part what is going in the trailer will be car, tool box, jack & jack stands,
fuel jugs.
thx for the responses
"Pistol" Pete Dutko
Old 01-19-2013, 02:46 PM   #10
Dave Turner
fuel jugs.
A trailer of that size really isn't designed to haul anything that would exceed the capacity of 3500lb axles. However, I sold my 20ft to a fellow who loaded up his Buick GN, towed out to Bonneville from Southern Ontario, and returned with no issues....
Dave Turner
SS/GT #1153
