Old 01-09-2013, 11:48 PM   #1
69stocker
Default What's the best spark plug wire
What's the best spark plug wires to use wanting some the headers will not burn. Looking to change to under the header wires on my Chevelle but going to see what works best.
Will Carrell
69stocker is offline   Reply With Quote
Old 01-10-2013, 08:14 AM   #2
RonTheAnnouncer
RonTheAnnouncer's Avatar
Default Re: What's the best spark plug wire
A friend of mine works and travels for FireCore wires. Not sure where you're located but he attends a lot of events, and will custom make and fit a set of wires on the spot. Good, high quality product.
Ron Huntley, Jr.
announcer and Half ed racer
"Those who can, do. Those who can't, criticize."
RonTheAnnouncer is offline   Reply With Quote
Old 01-10-2013, 01:43 PM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
I used Moroso wires with their sleeve material. I ordered the unfinished ones and fitted them myself. They won't burn if they touch the header. I also put the shrink wrap numbers. Makes it easy to trace the wires when they are below the headers. Have some silicone spray on hand when you pull the boots on.
Mike Pearson 2485 SS
Old 01-10-2013, 01:51 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
If you have a data acquisition system, contact the manufacturer for recommendations. They will tell you what to stay away from, not what to get. Not all wires are created equal.
Sean
Sean Marconette
84 Mustang
5060 SS/N
