Liked 4 Times in 3 Posts
More 2012 End of Year Stock and Super Stock Horsepower Adjustments Announced
Stock Horsepower Changes complete for 2nd half rating period 2012 Engine Make CID OEM HP NHRA HP New HP Years affected Mopar 318 230 182 172 69 Dart Mopar 440 390 390 385 69-71 GT Mopar 318 150 185 182 1973 Dart Mopar 440 385 411 404 1971 Charger http://www.nhraracer.com/content/gen...573&zoneid=132
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net Last edited by Alex Denysenko; 01-08-2013 at 04:47 PM. |
Liked 325 Times in 50 Posts
And....... your issue is?
Jeff Teuton 4022 STK |
The two 318 Combos are 2 Barrel with small carb and manifold.
They are not like the later 230 HP with a Thermoquad Combo. We were never able to run under the index with with the two barrel on our car Although it run over a second under with the four barrel combo on top of the engine. I do not think a few horsepower is not going to put them in top 16. What it may do is let a couple cars compete that I know of that otherwisecould not run the index. The 69 and 73 Combos are 2 Barrel ONLY and not able to run 4 Barrel (Four Barrel starts 78). |
no issues here Jeff I just like to see if I can wind you up, need to keep your blood circulating
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
#5 | |
Liked 419 Times in 85 Posts
Liked 43 Times in 9 Posts
I know which one your not going to build lmao. I don't understand how you can have more compression and less hp.
Sam Capizzi Jr. 1301 SS/AS 93 Dodge Daytona R/SA 73 Dodge Dart |
Liked 7,889 Times in 1,753 Posts
That 69 Dart is suddenly a very good "dime rocket".
Sam: What year combo and Horsepower is your
318 2 Brl. have you been running? I knew but I can not remember. Last edited by GTX JOHN; 01-09-2013 at 07:06 AM. |
73 dart
What I don't understand is why this is specific to a 1969 & 1973 Dart (only)? I
As far as I know, the 1967-1971 318 2bbl is identical from year to year. If not 1967-1971 at least several years are identical with the only deviation possibly a carb? And the 1972 318 2bbl is the same as a 1973 2bbl (and possibly the 1974 318 2bbl?). And why do Dart's get this new HP and not Valliants? Seems to me this should be all "A" body's with 318 2bbl's and auto trans; with the higher compression pre-1972 separated from the lower compression 1972 engines and later with similar specifications.
Jeff Lee 7494 D/S '70 AMX |
