Old 01-04-2013, 11:30 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1966-71 BBC Heads, Blocks, Cranks, Miscl.
3789733 11 inch 4 speed flywheel dated K-24-5 $125
3885069 aluminum intake with center plenum removed dated 12-2-65 $350
3885069 aluminum intake with center plenum partially removed dated 11-20-67 $350
1967 3904391 square port heads dated C-14-7 & C-15-7 stock $3000
1967 3904391 square port single head dated K-21-6 stock $1250
1967 3919840 square port heads rebuilt E-18-7 & E-23-7 $2500
1968 3919840 square port heads both dated L-12-7 stock $1250
1968 3919840 square port heads A-11-8 & A-12-8 stock $1250
1968 3919840 square port heads both dated D-23-8 stock $1250
1968 3919840 square port heads L-7-7 & L-11-7 ported $1000
1968 3919840 square port heads H-23-7 & I-18-7 stock $1250
1968 3919840 square port singles L-21-7, C-18-8, D-23-8, F-18-8 $500 and up
1968 3919842 aluminum square port single head 12-13-67 stock $1750
1968 396 4 bolt standard bore block #323 casting I-2-7 dated $1750
1969 396 4 bolt 30 over rebuilt shortblock #272 casting H-9-8 dated $2500
1969 427-435HP fresh 60 over block #439 casting F-14-8 $2500
1969 427 2 bolt standard bore #512 casting K-11-8 $1750
1969 427-430HP replacment block #289 casting J-7-71 stamped T1202LO $2000
1969 3919840 square port heads both dated B-20-9 rebuilt $1750
1969 3919840 square port heads both dated B-20-9 $1250
1969 3919840 square port heads I-17-8 & I-30-8 stock $1250
1969 3919840 square port singles J-29-8, C-27-9, G-31-8, D-30-9 & I-10-8 $600 and up
1970 3964291 square port heads I-10-9 & I-12-9 stock $1250
1970 3964291 square port heads D-14-70 & E-7-70 stock $1250
1969-70 3964291 square port single head rebuilt F-6-9 $750
1969-70 3964291 single square port heads F-18-9, K-3-9
1970 454 #512 casting 60 over 4 bolt block dated L-9-9 $2000
1970 454 #512 casting 120 over 4 bolt dated L-15-9 CE077789 $75
1970 454 #512 casting 30 over 2 bolt dated J-21-9 T1121CRT $1500
1969 427 #7115 steel crank standard $1000
1965-72 #6223 steel cranks $300 and up
1970-72 #7416 steel cranks $400
427 30 over 11 to 1 pistons with 7/16 dimple rods balanced to a 6223 steel crank $1000
396 427 8 inch harmonic balancer #3870325 $150
396 427 454 Chrome Dipstick $10
Chrome Factory Dripper valve covers (2) original sets $150 per set
BBC Factory oil pan $150
#964 4 bolt caps 396 427 454 $150 per set
1969 350-300HP motor #618 casting with 186 heads dated in early February of 1969 $1000
Can ship if you cannot pick up. 330-770-2517 for any questions or pictures needed.
dlv4540 is offline   Reply With Quote
