Old 01-03-2013, 08:27 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default 12 bolt 5.13 Richmond Pro Gear
This gear has about 50 runs in a foot brake small block. The gears look perfect. I changed to a larger tire and installed a 5.38 gear so no longer need the 5.13
The rear pinion bearing is still installed with a .032 shim.
$!50.00
Larry Woodfin
Kilgore TX
Larry Woodfin 471W
