Old 12-27-2012, 12:34 AM   #1
jethro
Default Tony DeCarlos SS/Comp parts sale
I AM POSTING THIS ADD FOR A FRIEND SO PLEASE CALL HIM FOR MORE INFO.
Tony DeCarlo @ home 401 521 5917 after 7pm EST...
CRANKS
Bryant
Stroke - 3.290 Rod - 2.000 Main - 2.450------$1500
Bryant
Stroke - 3.250 Rod - 2.000 Main - 2.300-------$1000
Callies
Stroke - 3.160 Rod - 2.000 Main - 2.450------ BEST OFFER
Lunati
Stroke - 3.160 Rod - 2.000 Main - 2.450-------BEST OFFER
OIL pump:
1 stock car products oil pump (DYNO ONLY never blown up) ---------$450 obo
850 Carbs ---------$700 each OBO
1- Fuel curve
1- PRC
RODS
8 - GRP (New) 6.050 2.000 Rod Pin .927 Pin------$600 obo
8 - GRP (Used) 5.600 2.000 Rod Pin .927 Pin-------$150 obo
6 - BME (Used) 5.600 Honda Pin .990 Pin------$150 obo
MISC ROD PINS .927 to .930, 2.250 to 2.750 - CALL FOR SPECS------$50 Each
CAM SHAFTS - CALL FOR SPECS
Buick Dart Head / Chevy Spayed V8--------$100 each
CAM BEARING'S
60mm Calico / Jesel 2.485 - 2.500 FULL SETS------$100 each set
BUICK / DART HEAD - PISTON & ROD COMBO
8 Used Bore 4.030 Rod 5.900 RJ 2.000 CH 1.530--------$300 obo
8 Used Bore 4.000 Rod 5.900 RJ 2.000 CH 1.250------$300 obo
8 Used - 2 New 3.935 x CH 1.355 Pistons-------$250 obo
SPLAYED VALVE
Jesel V8 Rockers 1.8 - 1.7 complete NO stands USED ---------$600 obo
INTAKES
Splayed Valve Chevy V8 Single 4 Barrel - Old Style-------$200 obo
Edelbrock Performer #2101--------$75 obo
HEAD GASKET'S
1 #1034 FEL-PRO----------$30
2 #7733 FEL-PRO Copper------$125 set
2 #7733 SH-1 FEL-PRO-------$50 set
2 Cometic Gaskets CV Product #C5325-------$125 set
SB2 Exhaust Gaskets - Steel Shim CV Product #C5552-065 ... 2 Pairs------$25 set
WHEELS
Centerline:
3 1/2" x 15"-------$150 set OBO
10" x 15"--------$200 set OBO
4 3/4" Bolt Pattern
Crager:
14" x 15"
5" Back Space
4 3/4" & 5" Bolt Pattern------------$350 set OBO
2 FRONT STOCKS (Carrera) FOR FIRST GENERATION CAMARO Part #3556---------$100 set OBO
1967 Camaro Front Brakes
Drums 9 1/2"
Used Shoes 2 1/2"
Two Hub's & Bearings
Backing Plate's - Wheel Cylinder---------$300 OBO
JESEL Push Rods-------$15 each
8- 8.600
15-8.750
8- 8.800
8-8.850
8- 8.900
8- 9.100
8- 9.150
8- 9.200
8- 9.400
8- 9.550
2- 9.600
8- 9.750
NEW Manley Valve springs ---------$10 each
#221450p and #221049
Manley spring cups 1.625------$50 set
CHEVY SB2.2 NASCAR VALVE TRAIN
CAMSHAFT - RCR DESIGN (DYNO TIME ONLY)
Intake Valve 2.180 x 5.715 6mm
Exhaust Valve 1.600 x 5.570 7mm
Rocker Arm's by T.D.
Retainer's - Locks - Springs - Spring Locator's
1.310 O.D.
Flat Tappet Lifter's .875 Diameter
Push Rod's by Smith Brothers
Intake 8.70
Exhaust 8.910
Have assortment of lifter puck's & lash caps to set valve lash
4 Dyno pulls on parts above
$4000 COMPLETE OR Will sell parts individually
jethro is offline   Reply With Quote
