Old 12-25-2012, 01:00 PM   #1
SmBlkFord
Default Coil wire through the firewall ?
What's the best advice for a coil inside car on my electrical mounting plate ? Can I use an a 2sided coil post on firewall ? Don't think there is any safety regulation on that ? Will try to keep coil wire as short as possible . Thanks
SmBlkFord is offline   Reply With Quote
Old 12-25-2012, 07:09 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: Coil wire through the firewall ?
The pass thru posts are a constant point of trouble.
burned /corroded posts,one more point for a wire to fall off.
Use a sleeve over the wire ,and find a grommet that fits close but not too tight.
Or better yet put the coil put the coil on the front of the head or the motor plate if you have one.
Old 12-26-2012, 08:51 AM   #3
FrankM
FrankM's Avatar
Liked 3 Times in 2 Posts
Jegs has firewall grommets with different hole sizes, here is the link
http://www.jegs.com/p/JEGS-Performan...21259/10002/-1
FrankM is offline   Reply With Quote
Old 12-26-2012, 07:37 PM   #4
SmBlkFord
thanks
