Old 12-12-2012, 11:13 PM   #1
wupracing
wupracing's Avatar
Default Parts ,Gears,Spool,Wheel Studs,Wheelie Bars
I have a Brand new set of 10 Screw in Wheel Studs 5/8 form Moroso Part #46140 will take $75 for them.Ever thing is there Studs, Nuts Spacer New in the Bag....
Strange Rear End Spool Part # D1555 It is the Lite weight Steel Spool It is for a 9" Ford it is 35 Spline.Will take $125 for it.....
Rear End Gears for a 9" Ford Rear.
All gears are in Great shape.$75 each
(1) is a 4.11 Gear
(1) is a 5.42 Gear
(1) is a 5.83 Gear
Also have a 12 Bolt Chevy gear 5.14 $75.......
I have (2) Used Turbo Action Valve Body
The first one is Part#17162 It is a Cheetah Street Manual/Automatic (PRN321) '62-'64, with a foot note that reads "push button"....
The second one is Part #17156 It is a Manual Valve Body It is for a 66-77 Torqueflite 727, 904 (Non Lock-Up)
Shift Pattern: PRN123
Will take $125 each for them OR sell both together for $225.......
This is a used set of Pro Style Wheelie bars they are 67" Long and are 20 1/8" wide center of bars.They are Spring Loaded.The wheels have not been put back on yet since they where powder coated.
They have just been Powder Coated Black at a cost of $150 and have not been put on anything.The bars cost $475 new and then had to be welded together I have $800 in them with the labor.Shipping is $20 in the 48 states
Email me for Pictures at dkm6416@att.net
Kevin Mclamb
IHRA H/R & Top/Sportsman #9416
wupracing is offline   Reply With Quote
