Old 12-09-2012, 11:59 PM   #1
swinehart
Default trailer tire pressure monitor systems
I am looking for some input on trailer tire pressure monitor systems. What are the pros and cons of these systems? what brands are my fellow class racers having good luck with? I am wanting to put a this on my motorhome and trailer. Let me know what you think or if you need any additional info.
Thanks
Jared
swinehart is offline   Reply With Quote
Old 12-10-2012, 12:17 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: trailer tire pressure monitor systems
I installed on of these kits for a customer on a 3 axle horse trailer , and it works quite well.
It's expandable for up to I believe 20 tires !
http://www.campingworld.com/shopping...g-system/13995
Old 12-10-2012, 12:38 PM   #3
KRatcliff
Liked 534 Times in 143 Posts
Thanks
Jared
Should prove to be pretty handy, especially if you have an entire axle come loose. You would see two of the pressure readings drop off your screen at the same time.
KRatcliff is offline   Reply With Quote
Old 12-10-2012, 01:40 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,202 Times in 977 Posts
We're Airstreamers and based on my experience this system and vendor are top notch. They can answer any technical questions as well.
http://www.technorv.com/TireTraker_T.../tt400c-4.htm#
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
