Old 12-09-2012, 06:00 PM   #1
Alan Warman
Default Small Block Mopar Parts for Sell
1-New 340X block std bore 9.600 deck 59 degree, lifters bores bushed. Pro Gram 4-bolt splayed caps, All the work was done by Ryan at Shady Dell-2800.00
1-New 360 R3 Block P4532910 std bore,9.600 deck.59 degree,with Milodn
4-bolt splayed caps not installed. 2500.00
1- Crankshaft Specialist 340 mains 3.75" crank 8-bolt flange Rods-.010 Mains-.010 fresh ready to go.-500.00
1- New Mopar Performance 340 mains 3.31" crank 8-bolt flange std std
700.00
1-set of used Eagle H-Beam rods 6.123 New bolts and bushings.-375.00
1-set of new Groden Aluim Rods 6.125 chevy pin .927 and chevy big end 2.100-500.00
1-set of new Ross 360 Pistons,4.065 bore, flat top, 2-ring style.-350.00
1-set of new Diamond pistons-4.118 bore,1.275 C/H,.927 Pin, flat tops
250.00
2-New short deck W2 Intakes,P4532966.-150.00 each
1-used Davinci 1050 Dominator-500.00
I have a lot more misc parts, Roller cams and lifters, 4" Eagle crank and Diamond pistons to match. Jesel rocker arms for A-heads. Call or PM here or e-mail me at maxzrx@g-mail phone# 325-212-4839 ask for Alan
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
