Old 12-05-2012, 07:12 PM   #1
art leong
Default Plug to piston clearance?
How much clearance should I have? Minimum? This is a hemi style chamber with the plug inthe center of the chamber. Pent roof piston, top of dome is under the plug.
Art Leong 2095 SS
Old 12-05-2012, 09:07 PM   #2
pmrphil
Liked 348 Times in 152 Posts
Default Re: Plug to piston clearance?
I would think (depending on RPM, bearing clearance, etc.) .035 -.040 should be plenty. At .030 I have seen a bit of contact at higher RPM (7200-7400)
Phil Molski
PMR Performance
S/C 1623
Old 12-06-2012, 10:17 AM   #3
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
usaully if misses without gasket (.039) will be fine,I always make sure plug is'nt shrouded
by piston, probaly won't be on hemi style.
Mike Taylor 3601
