Old 12-03-2012, 02:11 PM   #1
Bobby Zlatkin
Bobby Zlatkin's Avatar
Default leakdown on new engine
I have a newly assembled engine which I'm not happy with the results of a leakdown test.
My question is this; After running the engine for a while to seat the rings, can I expect to see an improvement?
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 12-03-2012, 02:30 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: leakdown on new engine
Usually.
Ed Wright 4156 SS/JA
Old 12-04-2012, 03:26 PM   #3
Reed Granrt
Has the engine seen dyno time if not that would be the first place I would put it so that i could put a slight load on it. also make sure you use breakin oil as it is formulated to help seat rings from the git go. If you use oil with friction modifiers in it, it will take much, much longer to seat if you ever do seat them. Todays lower tension rings need help to get seated. Or at least this is my .5 cents worth.
reed
Reed Granrt is offline   Reply With Quote
