Old 04-15-2007, 10:17 PM   #1
6682Bktrcr
Default 427 shortblock
427 060 4 bolt main with ARP studs
GM steel crank
GM 7/16 rods ARP bolts
Mellings oil pump with baffle
Milodon windage tray
Moroso pan
Ultradyne roller cam 710 Intake 710 Ex 304 Int 314 Exh 110 LSA
Comp Cams Roller lifters
Comp Cams Rev kit
7/16 pushrods
Cloyes Double Roller Timing Chain
AtI Balancer
Hays Flexplate
12-1 Manley Pistons
ARP Head studs
I am throwing in a set of closed chamber heads square port heads,Ferrara valves K-motion springs 10 deg locks.One of the heads has a pinhole in the exhaust port that goes into the waterjacket.I know there are guys that can repair stuff like this.
All the parts have 25 passes on themand were bought new
I also have a Team G with some mild porting and a Brodix Turtle installed
Avanti TRC preped 850 Carb
I am asking $4400 for the short block OBO
I will only sell the Manifold and carb once the shortblock is sold
This combo went 10 teens in a 3000# car I was having problems with the suspensio(4 link) I am sure it would of went faster once I sorted it out
Thanks for looking
cell 631-379-2128
Louie
6682Bktrcr is offline   Reply With Quote
Old 04-16-2007, 12:02 PM   #2
6682Bktrcr
Default
P.S. heads were ported and polished by Brandywine Cyl heads.If someone can repair that port they will have a nice set of heads.Im going heads up racing otherwise I would of had them fixed
Louie
Old 04-24-2007, 07:49 AM   #3
6682Bktrcr
Default
Need to clean out garage I will throw in the manifold and the carb.
Take all for $3700 .Lets deal !!
Louie
