Old 11-17-2012, 02:08 PM   #1
John H186
Default New and Used parts.
I am interested in some trades and am looking for a good Powerglide trans as well as some fox-body Mustang parts. Text me what you have.
Stock block Ford 302 (310 ci) bracket engine. Has numerous top-notch components such as Manley, Jesel lifters and rockers and Ross. Ran 11.44 at 116 mph in 2950 lb Mustang off the footbrake with NO NITROUS! Two std bore, stock blocks go with engine as well as numerous spares. Complete and ready to run straight out of my car minus carb. $3500 obo. Call for exact info.
Ford Dynamic C4 transmission with standard gear ratios set up for footbrake racing (no t-brake). Have numerous replacement components plus spare C4 case, bellhousing, tailshaft and 8-inch converter with approx 3000 (flash) stall behind 375 hp 302 Ford. Also have Hurst Pro Stick shifter for it. Make offer.
Jesel black medium jacket with Jesel logo on back and front left with leather sleeves (looks like NHRA Champion-type jacket). Worn maybe four times. Perfect condition. Paid $140, will sell for $50.
New still in box Lakewood 90-10 struts for '82-up Camaro/Firebird. PN 40510. $150.
New still in package Manley SB/BB oil pump primer. PN 42336. $40.
Three used Zues tools. $10 for all three.
Engine plate for hoist chain. Bolt on to standard carb intake. $10.
Used Blue Point tire gauge. $20.
One used CSI liquid filled, tire gauge with light. $75.
Three used air shifter bottles. $75 for all three.
New still in box Auto Meter 2-inch water temp gauge. PN 2432. $20.
Used Blue Point cordless drill with charger and case. $75.
Used Simpson Avenger full-face helmet with visor. White, M2005, XXL. Have brand new padding to make inside smaller. Make offer.
Used HJC open-face helmet. M2005, XXL. Make offer.
Used upswept stainless Dragster headers with Borla collector mufflers for SBC Brodix heads. Make offer.
Used Dedenbear throttle stop controller. Model TSC-2. $25.
Used Davis Racing Products Ultra Box, multi function crossover delay timer. $25.
Used Simpson black 32A-5 pants. $25.
Three used Mallory four-port fuel pressure regulators. PN 4305M. $100 for all three.
Three used Mallory Hi-Fire 6 ignition boxes. PN 685. $50 each.
Used Holley carb parts. Bowls, metering blocks and two 390-cfm main bodies. $100 takes all of it.
Used Powerglide valvebody. Make offer.
Used 8-inch Powerglide converter. Make offer.
New B&M SBC SFI flywheel. PN 20230. $50.
New B&M 8ft Super Duty shifter cable for Pro Stick, Megashifter and others. $40.
New CSI U-Flex push/pull 15-ft cable. $40.
Used RCI 10-gallon plastic fuel cell with straps and foam. Has new cap! $75.
Used stand up-type conventional battery charger. $25.
Fresh, Zero Runs Metric 200 Stocker trans. Not sure if its a low gearset or not but built by Dynamic. $1000 obo.
New still in plastic bags Jesel small block Ford, Pro Series shaft rocker arms. 1.60 in/ex with Mohawk slot and fully optioned. Will fit SBF inline-type heads such as Dart and Ford, etc. Make offer.
Tons of white MSD chips from 3000 rpm to 8400 rpm. 16 in total. Make offer.
Used Ford 4.6L aluminum underdrive pulley kit. $25.
New never installed Ford Focus underdrive pulley kit. Made by Focus Central. $25.
New Rock Industries 12V/16V battery. Make offer.
Used small block Ford Holley mechanical fuel pump and Magnaflow fuel pressure regulator. $100 for both.
Tow bars for hitch with brackets and chains. These are the load bars used in conjunction with the hitch for the front of a tag trailer. DO NOT have the hitch, just the bars and trailer brackets. $50.
Hundreds and hundreds of plastic AN fitting plugs. All sizes and types. Great for capping fuel and oil lines. Make offer.
All parts are located in Central, NJ and do not include shipping.
Please text or call me at 732/910-2145. Do not PM me as I have a hard time responding that way. Thank you for looking.
John Hedenburg H186
Last edited by John H186; 01-19-2013 at 11:22 AM. Reason: Updated and added to list as of 1/19/13.
John H186 is offline   Reply With Quote
