Old 11-17-2012, 11:31 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1965-72 396 427 & 454 l78 l71 l88 ls6
396-375HP 4 bolt standard bore block #3916323 stamped T0926EG 18K113862 out of 4 speed 68 chevelle $1750
396-425HP 4 bolt standard bore block #3855962 dated D-2-5 stamped T0527IF 5119689 out of 65 corvette 4 speed 1 of 2157 built $5000
427-335HP 2 bolt standard bore block #3963512 dated K-11-8 stamped T1201LE out of 69 impala $1750
427-425HP - 435HP 4 bolt 120 over block #3963512 dated L-8-8 and decked for a 1969 dated application $750
454-450HP 4 bolt 60 over block #3963512 dated L-9-9 decked for a 1970 application $2000
454-450HP 4 bolt 120 over block #3963512 dated L-15-9 stamped CE07789 for a 1970 and back replacment block $750
454-360HP 2 bolt 30 over with 1 sleeve block #3963512 dated J-21-9 stamped 10A121807 T1121CRT for a 1970 chevelle 4 speed application $1500
427-430HP 4 bolt standard bore block #3999289 dated J-7-71 stamped T1202LO for a 1969 427-430HP M22 corvette application but could also be used for a 1970-71 LS6 replacment engine block as well $3000
3904391 heads bare stock set dated C-14-7 & C-15-7 $3000
3909802 heads complete with rockers both dated B-7-7 $500
1967-69 3919840 heads
1969-70 3964291 heads
1969-71 3946074 aluminum heads service dated complete $1750
1968 3919842 stock single dated 12-13-67 $1500
1971 3994026 heads bare both dated I-9-71
3933163 aluminum intake 2-5-69 $425
3933198 aluminum intake dated 6-29-71 427-430HP $500 (1969)
1970 4557 Holley Carb dated 9B1 complete LS6 & L78 $850
1969 4346 Holley Carbs with various dates
7115 427 only standard crankshaft $1000
7416 standard cranks
6223 standard and 10 under cranks
3/8 dimple rods $300
8 inch timing cover $125
BBC oil pan with bolts $150
Richmond 4 speed tranny all rebuilt with a fine spline input shaft and 400 tailshaft with complete hurst shifter and linkage set up $1250
330-770-2517 for any questions or pictures needed. Can ship if you cannot pick up.
dlv4540 is offline   Reply With Quote
