Old 05-01-2007, 10:06 AM   #1
Ray Martino
Default Small Block Ford Parts
All parts listed were used on combo that ran 11.00's @ 122 mph.
-E7TE 5.0L fully ported heads c/w 1.94/1.60 ferrea valves, guide plates, 7/16" studs-$750.00
-Custom solid roller cam 605/583 lift 242/253 duration @ 106 centreline .010" lash cam complete with Crane solid roller lifters-$450.00 (only 30 passes on set) Valve springs also available for cam-$50.00
-Stock polished and race ground-.010/.020,balanced crankshaft-$125.00
-SRP Forged dome pistons 4.030 bore 12.2 compression with 62 c.c. heads-$350.00
-Eagle H-Beam 4340 5.090 bushed rods mounted on the listed pistons only 30 passes on rods-$300.00 if bought with pistons
-various stock parts available- 8.8 posi unit c/w extra clutches- $50.00/ stock axles c/w long studs-$50.00/ 3:08 gears-$40.00
Call Ray @ 905-765-1018
Ray Martino is offline   Reply With Quote
