Old 11-04-2012, 05:08 PM   #1
FED 387
Liked 333 Times in 180 Posts
Default End of season parts sale
ALL PARTS ARE PLUS SHIPPING!!! Many of these parts were either spares or for projects we changed our mind on.
1 Each used Reactor 168 tooth flexplate internal balance fits Chevy- good condition--$75.00
1 -Each used MSD 8251 coil--$50.00
1- Each NEW in the box MSD 8261---$120.00
1--Each used CSR Turbo 350-400 Alum tran shield Blue powdercoated ---$50.00
2 --Each--used Chevy SFI flexplate shields--$25.00 each
1--Each-- Hughes Powerglide trans shield--$50.00
several ATI balancer shells and one complete balancer SBC snout shell is faded, plus one balancer MINUS the hub really great condition--- really enough parts to make probably 2 good balancers out of it ---ALL are 6 3/8 inch diameter---$200 for the lot
1--each --WELD Aluma Star NEW never had tires mounted or drilled 15"x12"x4" Back space and 4/34 Bolt pattern-needs a little buffing from sitting around---$300.00
1---each---WELD Aluma Star NEW same info as above but 3 inch back space--$300.00
ONE pair Mopar P7 heads as from Mopar need finishing---$375.00
used set of JESEL rocker arms shafts ,mounts,bolts etc for P7 heads may fit other makes of heads---$500.00
1--Each-- Chapman ported Mopar W7 head cost over $2300 new---make me a reasonable offer!!!!
PM me for contact info or more info regarding parts----Shipping will be by UPS GROUND from Zip code 60047
Dick Ullrich
FED 387
