Old 11-02-2012, 09:10 PM   #1
SS 230
Default 86 camaro G-H/SA
305/263hp, Josey heads,Bullet cam and lifters, Comp Cams new pro magnum rockers and 3/8-.130 wall pushrods,JE .040 pistons,Eagle SIR rods,Bullet crank with .013 stroke,Headman Headers with nitroplate. 200 metric with torrington bearings throughout,reverse valve body, B&M cooler. 12 bolt rearend, Strange light wt. spool, lightened richmond 5:13 gear,Moser axels star flange and gun drilled, Aerospace brakes on all four corners,M/T wheels and tires,Aeromotive,JAZ,Earls,Turbo Action shifter,MSD,Autometer. New: GM nose,weatherstripping,interior, paint. Undercarriage is base coat-clear coat same color as car.Everything is powdercoated,anodized,or blackoxide. 11:40's in good air /11:50's-60's in bad air. Build was completed in 2010. Detailed pictures are available. $18,500
Gary Norman 904-966-1824 (anytime)
SS 230 is offline   Reply With Quote
Old 11-05-2012, 03:06 PM   #2
cicero819
cicero819's Avatar
Liked 69 Times in 30 Posts
Default Re: 86 camaro G-H/SA
you have a pm.
