Old 10-31-2012, 04:47 PM   #1
Shawn Pinkerton
Default 2011 Shelby GT 5.4 Motor Complete
Please call for detail infomration. Call JP or Paul 330 692 0652
As Described by Ford Motorsports:
For car builders looking for real power, Ford Racing offers the Supercharged 5.4L engine from the 2011-2012 Shelby GT500. The engine is the most powerful in Ford's Mustang production engine line-up and an excellent choice for a high-end street rod or Mustang "retro-mod" project. Its shipped fully dressed and includes engine accessories and supercharger. The lighter aluminum block is reinforced with structural webbing, a unique bulkhead chilled process and incredibly strong six-bolt billet main bearing caps for high-performance durability. Larger oil drainbacks and an integrated windage tray improve oil control in extreme driving conditions. You are buying the motor as shown in the photos.
Note: Does not include vehicle wiring or Powertrain Control Module, works with M-6017-54SC 5.4L supercharged controls pack
•550 hp @ 6200 RPM,
•510 lb-ft of torque @ 4250 RPM
•5.4L modular engine
•Displacement 330 cu. in.
•3.552 bore x 4.165 in stroke
•Aluminum block with Plasma Transferred Wire Arc (PTWA) cylinder liner coating
•Forged steel crankshaft
•Cracked forged steel I-beam connecting rods
•Forged aluminum pistons
•DOHC cams with roller finger followers
•Aluminum cylinder heads, four valves per cylinder, Intake 37.0 mm, exhaust 32.0 mm
•8.4:1 compression ratio
•Roots-type Eaton supercharger with integral intercooler
•60 mm throttle body
•Shipping weight 717lbs
Shawn Pinkerton is offline   Reply With Quote
