Old 10-31-2012, 08:57 AM   #1
Shawn Pinkerton
Default BBC aluminum 582 3xtra-O
Brodix Aluminum Block- half filled
Brodix Intake
Brodix 365 3xtra-O Heads
T&D 1.75
PAC Springs
Manton Push Rods
Crower Sever Duty .903 lifter
Comp Cam 808/798 278/294 112LS
Diamond Pistons
Eagle Crank
Eagle Rods
Jessel Belt Drive
Tital Oli pump
Mildon pan
Block, lifters, springs and cam where all new this season when motor was freshened.The rotating assembly has 2 seasons and roughly 350 runs. If motor does not sell we will check the lifters and run next season. Motor was in a 1900# swingarm dragster with 34.5 beadlock and 4.10 gear. Motor ran 4.70's/7.40's leaving at 4400 and shifting at 7100. Motor is well maintained and not run hard. Original block/motor combo was not hurt. Switch to aluminum for weight savings only.
Motor will not have coil, water pump, vacuum pump or distributor.
Asking $17,500 obo
Call Dion at 330-584-3679 with questions or offers.
Shawn Pinkerton is offline   Reply With Quote
