Liked 227 Times in 74 Posts
Hi im planning out a 1970 or 1971 Torino Stocker and im thinking about what Ford engine would work best and what do you run in your Ford Stocker or Super Stocker and what would be the best bang for the buck?I keep thinking 351 Cleveland and what Tranny do you run and what works best?I keep thinking clutchless Liberty or plain Automatic?Im sure some Ford guys on here would enjoy discussing this or atleast im hoping you enjoy this topic? THANK YOU anyways
I`m not sure if the Torinos were the same, but in the Mustangs, the 70s had to use the autolite 4300 carb, while 71 & up were able to use the aluminum intake and Holley 780. The 70 also had a smaller cam, so if you do chose a Cleveland, you may want to find a 71 grille. I always thought that the 429s were rated kinda high, but I believe they had some HP taken off not too long ago. I`m a stick guy, but those Torinos are pretty heavy.......
If you can get NHRA to correct the Stock Car Classification Guide, the 429/375 rated at 360 would be a very good combo. It would a natural E car if you claim it as a Cobra Torino. The Problem is they don’t show the 375 engine. Having owned two of these cars, I know they came with the 429/375. What makes this a better engine than the 370 is the 375 gets a solid cam and 780 Holley. If you can get NHRA to correct the guide it would be an easy 8 under combo. The 71 Mustang with a 429/375 is rated at 360. This engine was available in all Torino’s, Mustangs, Montego’s and Cougar’s in 1971.
Well im also considering Super Stock by the way if anything in Super Stock would be easier?
Liked 16 Times in 11 Posts
Forget SS unless you own a bank, Stocker's are enough of an expense to build. SS is over the top. Much cheaper to buy a car than build as you will soon find out.
Bob Pagano A/SA |
#6 | |
Liked 2 Times in 2 Posts
In my humble opinion. If you aren't emotionally attached and haven't really invested anything in the ride you have you might be better off to find a later model Mustang and go SS/GT with one of the new pushrod paper motors. To me that would be the easiest and most affordable way of getting out there. But either way I would go with a stick if you want to have fun and enjoy the time going down the track. Now if your wife, girlfriend or daughter is going to be driving it then I would recommend the automatic ![]() ![]() Best of luck to you.
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
Liked 20 Times in 9 Posts
What i did just this year was sold my 1969 mustang cj car and bought a ford stocker,and once i found out all of the things that were needed to to get this car to run like it does i am glad that i bought a car rather than trying to build one, the car's that run way under the index or really complicated and expensive.
#8 | |
#9 | |
