Old 10-09-2012, 12:08 AM   #1
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Default MSD help ( Pat Collins )
I am working on a friends bracket car, it has a electrical pop at idle. I think I found the problem, when I pulled the coil wire off the coil oil ran out of the coil wire boot. It has a MSD 6420 box and a blaster 3 coil. I need to replace the coil, what coil would you suggest?
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 10-09-2012, 01:29 PM   #2
Monte Howard
Default Re: MSD help ( Pat Collins )
Pat,
Thanks for the quick reply, I will be purchasing one tonight.
Thanks again,
Monte.
Old 10-09-2012, 04:13 PM   #3
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Pat, would msd coil # 8207 be acceptable to use with a 6al, seems to be a epoxy filled. John gsa612
