Old 10-06-2012, 06:25 PM   #1
Grant Eldridge
Grant Eldridge's Avatar
Default 396/325 HP Stock Eliminator engine.....
Fully sleeved 454 block, CP pistons, '290 small plug heads w/special valve job, hollow stem valves, small spring pkg, Bullett cam, tool steel lifters, Holroyd rocker system, Manton pushrods, baffled trap door oil pan w/heater etc. Long list of high dollar parts and custom machine work... Best et at 3450lbs 10.79 in E/SA .91 under index. Last weekend 10.91 at 1200-1500 air. Can be heard running, still in car exactly as run. National Record Holder May 2011@10.87 $6500. or reasonable offer. Would take street Muncie four speed setup as part trade, what do you have? Also have 1969 manifold available, 350hp camshaft to run the 350hp version of this engine if needed. Engine buyer may also buy Step Tri-Y headers w/burns collectors for '67 Camaro as run in car.
Grant Eldridge
604-644-8485
grant4060@yahoo.com
Last edited by Grant Eldridge; 11-02-2012 at 10:48 PM. Reason: Added details, price change, added parts available...
Grant Eldridge is offline   Reply With Quote
