Liked 427 Times in 97 Posts
Gm 4-bolt main block, bored .030 over, Keith black pistons 11.9 compression,
Fluid damper harmonic balancer Gm "LT-1" rods with ARP rod bolts, Comp cams solid lifter cam .562 intake .557 exhaust, high volume oil pump, Air flow Research Aluminum heads (215),w/Air Flow Research ported intake manifold, Crane Gold Roller Rockers, 7/16 push rods, much much more, Engine ran consistent 11.40's & 11.50's in a 3500 lb Chevelle... Just the heads and intake are worth the asking price! $2500.00 cash, 508-769-7867 |
