Old 08-31-2012, 12:42 PM   #1
Mike Gardner
Default 07 Don Davis Top Dragster
243" Don Davis swing arm chassis
16 x 16 rear beadlock Weld Wheels (powder coat Black)
Weld Front Wheels
16V Rock Battery
Spaghetti Menders Switch Panel and relay block
Wired for 2 stages of Nitrous
Racepak Dash
Mega 450 delay box
B&M Bandit Shifter w/ electric shift solenoid
Poured seat for 220LB man
ISP Helmet pads
MSD Digital ignition #7530T
Simpson Belts New July 2012
Ron Davis Radiator
All Aluminum 16degree PAR 632, Just freshened July 2012
Dedenbear HD Powerglide Trans built by Bernard Weaver
All Strange Rear and Brakes, 40 Spline
Spitzer Carbon Fiber Wing
Dual Stroud Chutes, mount fabricated by Racetech in 2010
Penske HD Gas Shock
1320 Vinyl Wrap. Wrapped over nice Black Paint job.
Car runs 7.teens in bad air w/o nitrous
Ran 6.82 @ Maple Grove on 1 stage .800 out 4.20 duration
One Owner Car, has won NHRA and IHRA races and only has run NHRA and IHRA races, has low run total, not your weekly bracket racecar.
$22,500.00 less engine & converter but w/ spare Hughes HD mid length gear set and tail shaft housing
$47,500.00 Turn Key w/ spare Hughes HD mid length gear set and tail shaft housing.
Call Mike Gardner 703 675 4479
Mike Gardner is offline   Reply With Quote
