Old 08-23-2012, 11:34 AM   #1
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default 4.5 svo v-6 engine
I have a 270 cid ford svo v-6 x-nascar motor that i an selling can"nt afford to give it what it needs maybe someone else can max it out.4.036 bore with J&E flattop pistons and roller cam bearings,Lentz billet connecting rods,bryant 3.520 crank 2.100 rod journals,moroso dry sump pan with windage,fluid damper,j-380 cylinder heads ***.intake and exhaust vlvs.36 cc combustion chambers,comp roller cam and lifters,manton 3/8 .120 wall intake pushrods,7/16 .120 wall exhaust pushrods,jesel pro rocker arms,2 660 carb on sheet metal intake,dry sump tank and pump,motor plate,stepped headers that can fit in a tube chassis car or use as dyno header,msd 7/al calibrated for v-6,msd v-6 distributor alt.and brackets and pulleys.spare parts include another v-6 rotating assy.even fire 3.480 stroke with 2.00 rod journals,carrillo 6.300 rods,wisco 4.059 flattop piston new,svo internal balanced damper.two powerglides,1.82 and 1.94 6600 stall convertor,JW bellhousing and flex plate.This class of engine will fit in superstock Ax,Bx,Cx and (Dx with a turbo)right now the engine makes 535 hp 400 #ft torque and it is ready to run with low 1/4 quarter mile runs on it.I am asking 12000.00 for everthing are trade for a good 428 cj stocker engine ,convertor and transmission.located in southern california.It has run 10.08 at 129 in a 2500 # car.
astikhossw is offline   Reply With Quote
