Liked 719 Times in 220 Posts
Who makes a stamped steel SBC head gasket .038-.040" thick compressed? Got a deck height issue I'm trying to correct. Also, what is the part number? Thanks!!
Nobody , just run a composite gasket. ---Trevor
Liked 1,851 Times in 418 Posts
There is no single steel or stainless shim gasket I'm aware of.
Cometic has an MLS gasket that will be in that range, you can pick your bore size, and you can use them 3-5 times if you're careful. They pay for themselves that way.
Alan Roehrich 212A G/S |
Liked 1,436 Times in 299 Posts
We use cometic head gaskets all the time. They make nice stuff. As Alan said, they can be reused several times. I just tried out their mls header gaskets recently, and they are awesome! Tell them the thickness, bore size and engine.
James Schaechter 3163 STK |
