Old 08-13-2012, 10:24 PM   #1
Hagen Gary
Liked 34 Times in 10 Posts
Default Stock-Super Stock Garage Sale
S/S PowerGlide Transmission 196 Gear w/ Hardered input & Tailshaft;s, Roller Bearing Tail Housing High Volume Low Pressure, Pans & Shields A.T.I. sets - fresh $1,700.00
Step Headers For 82-92 Camaro, Small Block - Used, Fair Condition $300.00
TCI Transmission Shield For Turbo 350 Brand New(never installed) $125.00
Early Version Super Stock SBC 041 Head with Matching intake. Heads-Up Heads None Welded Exhaust - Great Shape $1,500.00
Simpson Large Pants 32A-5, Used but in Good Shape $75.00
8" A.T.I Converter 5800,Fresh PowerGlide Spline $450.00
Davis Step Headers, 82-92 Camaro, coated w/Collectors Brand New(Never Run) $1,750.00
9" Ford 567 ProGears, Lightened- Great Shape $275.00
Holley Carb 780 C.F.M. - Good Shape $400.00
Barry Grant 400 Fuel Pump - Just freshened $150.00
Jr. Dragster Roller - No Motor - 1/2 Scale Chassis BG $3,000.00
Camaro Hood 82-92 Camaro Hood w/super Mod scoop, Painted Clear White $550.00 Great Shape
Weld Wheels 13" wide 5 X 4/34 4" B.S $650.00
Elisha Boyd Built S/S Motor 350/300 w/041 Head-Up Heads BME Pistons $8,500.00
E. Boyd 350/255 S/S Motor Complete 441 Heads Up-Motor needs to be rebuilt $6,000.00
MSD 7ALS3 Box Used Dyno Time only - New $450.00
69 Camaro Front End Leather work cover - New $400 $200.00
Merged Collector Stainless 2 1/8"X4", New-2 passes Perfect Shape - New $550.00 $350.00
Munsinger Convertor 8" 6000 Staul (not used sense Freshened) $750.00
A.T.I. Convertor 8" fresh 5800 Staul (Turbo Spline) $650.00
Munsinger Convertor 8" 5800 Staul 50-60 passes since fresh (Fast Convertor) $700.00
Meziere Water Pump Used small block #WP301X $250.00
(2)TCI Starters SBC/BBC $50 each
Crane Lifters 14 New In Box #11515-16 $250.00
Pro Ford Ring & Pinion Two sets of 583 Backcut Lightened (one at $200 & one at $250)
K-Motion Spring Set, New in Box $200.00
MSD 2-Step Used $35.00
Trans Brake Solenoid Old Style (TCI) $50.00
3 Trans Brake Buttons w/cord's - 1 Reg, 2 Mushroom $45.00/each
AutoMeter Fuel Pressure Gauge $35.00
KNOI Front strut for 82-92 Camaro or Firebird- New Never Ran $100.00
(2) 440" Comp Cams Roller Each $200.00
Moroso S/S/or Comp Oil Pan #21235- New ($675) $250.00 (needs right side rail & screen replaced)
Used 947 Comp Springs & #818 Lifters Used 60-80 Runs ---- Call for Prices Many Sets
396 Rocker Arms & Studs & Adjusters for Stocker Chevy $100.00
Performax 26" Trailer Loaded , Great Shape 6,000 LB Axle, Custom Side Load Golf Cart, Fresh Tires, Brakes, & Bearings NEG $14,500.00
Texas Trailer Man Trailer Custom Open Trailer 23' Bed wi/Box. 5200 lb. Axle, 4 wheel Brakes Tongue Jack split tail L.E.D. Lights $4,500.00 NEG
2009 EZ Go Golf Cart Custom Golf Cart like new. Loaded w/ options $8,500.00 NEG
All Prices are Negotiable. Contact Harvey at 337-258-5564
Hagen Gary is offline   Reply With Quote
