Old 07-27-2012, 08:33 PM   #1
Unhappy '06 Journey - Exhaust fumes inside
Driving me nuts trying to find out where the exhaust fumes are coming in at - had it to two local RV dealers and both took money but no results .Starts coming inside after driving 45 minutes or so - helps if you shut rear bedroom door so i'm sure its coming in back there .2006 Winnebago Journey with Cat 350 hp engine .........heeeeelllllppppp .
Thoughts ......ideas .......anything
Maybe if I left 5 gallons of gas in the bedroom the problem would disappear .With the luck I'm having this year nothing would happen .........
Old 07-27-2012, 09:32 PM   #2
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: '06 Journey - Exhaust fumes inside
Jack is it coming out from under the bed
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 07-28-2012, 07:54 AM   #3
Lightbulb Re: '06 Journey - Exhaust fumes inside
Mark - I really can't tell without seeing some smoke or something ......but I checked the seal around the engine cover - its OK - and I couldn't find any signs of soot around it .
Old 07-28-2012, 10:11 AM   #4
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
I agree... We had our bed out for some repair and it did the same thing... Pulled the bed out and put it back in the same place and its gone.... Can't explain but it is.... FYI.....
Mack Reeves
2377 STOCK & SUPER STOCK
