Old 07-23-2012, 04:59 PM   #1
JeffM
Liked 5 Times in 5 Posts
Default Garage Sale
Make offer! Can bring to Bowling Green Points meet in late August.
Pair of 041x heads - Cleaned, magged and pressure tested bare stock - $400.00
Pair of 461x heads – (L32, and E153) Cleaned, magged and pressure tested bare stock - $500.00
327 Forged Crankshaft std std – will need to be turned likely .010/.010 $125
QJ Performance 207 Quadrajet for SBC Superstocker by Danny Ashley. Built in 2011. Very nice condition. $500.00 obo
NOS Rod bearings in original packaging- $20.00 per set of 8
CB663P – 2 sets of 8
CB663P-1 – 2 sets of 8
CB663P-20 – 1 set of 8
CB743P-1 – 2 sets of 8
CB743P-10 – 1 set of 8
CB745H – 1 set of 8
CB745P – 2 sets of 8
CB745P-10 – 1 set of 8
CB745P-30 – 1 set of 8
NOS Main Bearings in original packaging
MS429H – 2 sets - $50 per set
MS429P-20 – 2 sets - $50 per set
MS429P-20 coated – 1 set - $100
MS829P-30 – 1 set - $50
NOS piston rings in original packaging
R20109-5 - 4.125 in. Bore, 0.043 in., 0.043 in., 3.0mm $125.00
R20109-65 - 4.180 in. Bore, 0.043 in., 0.043 in., 3.0mm $125.00
R20100-65 - 4.060 in. Bore, 0.043 in., 0.043 in., 3.0mm $125.00
R20101-5 - 4.000+5 in. Bore, 0.043 in., 0.043 in., 3/16 $125.00
E377X - 4.000 in. Bore, 5/64 in., 5/64 in., 3/16 in. $20.00
Dana 60 rear differential with Summers brothers spool, Richmond 5.86 - 9310 pro gear with lightened ring gear. Approximately 60 runs on this rear end. Moser 35 spline axles, gun drilled and star flanged with 5/8 studs spacers and lug nuts (chevy bolt pattern) TA performance Aluminum rear girdle. Moser 1350 yoke. Ladder bar brackets and wheelie bar brackets. Wheelie bars included. 49” axle flange to axle flange. Comes with Strange caliper brackets. Just took out of 66 Chevy II Superstocker. Ran the last time last fall. Ready to run. $1400.00
260-223-0157 or superstock@live.com
Jeff Myers
SS3254
S1522
JeffM is offline   Reply With Quote
