Old 07-20-2012, 11:14 AM   #1
dlv4540
Liked 2 Times in 1 Post
Default 1969 350-300HP Motor
1969 350-300HP motor standard bore block casting number 3956618 dated A-4-9 with front pad stamped V0211HN. 3927186 heads complete with rockers all stock dated A-30-9 & B-7-9. Cast intake 3927184 dated B-8-9, cast standard crankshaft 3932442 dated B-6-9. Motor comes with original pistons and rods, pushrods, headbolts, camshaft, oil pan, dipstick, timing cover, timing chain, harmonic balancer, oil pump, fuel pump (aftermarket) and edelbrock valves covers $1250. Can ship if you cannot pick up. Perfect stock engine. 330-770-2517 for any questions.
Last edited by dlv4540; 07-21-2012 at 10:44 AM. Reason: The block stamping starts with a V for Flint Michigan.
dlv4540 is offline   Reply With Quote
