Old 07-01-2012, 11:20 AM   #1
Rugged Racing
Default 87 MONTE CARLO SS S/ST, Bracket
87 MONTE CARLO SS
CAR
· 12 point 4130 chrome moly cage (8.50 cert)
· Moser 9” Ford with heavy duty backbrace, 35 spline axles, 4:56 gears
· Jerry Bickel Anit-Roll set-up
· Custom driveshaft with strange yoke
· Competition Engineering front & rear shocks
· Strange Heavy Duty front disc brakes
· 5 gallon fuel cell
· MagnaFuel 280 fuel pump(just rebuilt by MagnaFuel) and fuel filter
· BG fuel regulator
· Kirkey aluminum racing seat
· Aluminum glove box
· M&R safety belts
· M&R safety window net
· C&F custom removable dash
· Hurst Quarter Pro shifter with electric shifter solenoid
· Billet Specialties Street Light wheels
· Hoosier front tires 28x4.5x15
· Hoosier rear tires 28x10.5x15
· 4” fiberglass cowl hood & hood scoop
· MSD 7AL2 plus igntion box
· MSD Pro Power Coil
· MSD noise filter
· MSD 3 step
· MSD Crank Trigger
· MSD Distributor
· Biondo Mega 450 delay box
· Autometer gauges
· 2 Optima batteries
TRANSMISSION
· Select Performance Powerglide Transmission
· Select Performance 8” Converter
· Dedenbear SFI Case
· 1.76 gear
· Transbrake
· Transmission cooler
MOTOR
· JA Performance 406 SBC
· Chevy bow-tie block
· JE pistons
· Crower rods
· Callies crank
· Comp Cams camshaft
· Comp Cams roller lifters
· Comp Cams valve springs
· Crane rockers
· Crane stud girdle
· ATI balancer
· Hooker headers with nitro plating
· 950 HP Nickerson carb
· CSR electric water pump
· Powermaster 110 amp Alternator
· Dedenbear under the carb butterfly electric t-stop
All New SFI's, Trans Case, Belts, Window Net, Flywheel
$17,000 Turn-Key Complete
It runs 10.90 at 127 on the t-stop and 10.13 at 132 off the t-stop.
Call Ryan 516-807-0768 or
Email RuggedRacing1900@aol.com
Rugged Racing is offline   Reply With Quote
