Old 06-27-2012, 08:48 PM   #1
Robbie Welch
Liked 262 Times in 124 Posts
Default 16 Volt Battery
I'd like to put a 16V battery in my car. I run Dedenbear delay box (the old CO2 model) and thottle stop controller. I also have an ACD air shifter and a MSD dist and 6AL2 box. Well these be OK with the 16V? Thanks Robbie
Old 06-27-2012, 09:01 PM   #2
Chuck Westcott
Chuck Westcott's Avatar
Talking Re: 16 Volt Battery
Robbie,
I've been using 16 volt Batteries for as long as I can remember - maybe 15 years or so.
They won't efect anything your using currently including the the 7AL2 which I currently have.
Just Charge them between runs with the Master off. They will go quite a few rounds without charging at all !
Chuck Westcott- S/C -S/G 225
Chuck Westcott is offline   Reply With Quote
Old 06-28-2012, 11:57 AM   #3
THE LEGEND
Default Re: 16 Volt Battery
Robbie,
I run ROCK 16v. Hvae since 2008. When I switched I called the companies and asked. Most said everything produced in the las 10 years was compatible(keep in mind that was 08).
You should be fine, and like Chuck said keep the charged.
Chip
THE LEGEND is offline   Reply With Quote
Old 06-28-2012, 09:11 PM   #4
Robbie Welch
Thanks for the replies guy's, I've order a battery and charger already. Can I still run my standard alt or do I need to switch to a 16V alt.
Old 07-04-2012, 04:51 PM   #5
drgrcr1156
Liked 2 Times in 1 Post
Anyone consider using or are using the XS Power 14v battery?
Bob
drgrcr1156 is offline   Reply With Quote
Old 07-04-2012, 05:29 PM   #6
Dragsinger
Liked 99 Times in 60 Posts
speaking of the 14 volt battery. Since it requires a dedicated charger and alternator you may as well do the 16 volt package. The 16 volt deal is very good, once you try, you will always buy
And like Chip posted, my experience with Rock Battery's bought from Mark Payne is very positive [no pun intended] These comments are grounded in experience.
Larry Woodfin 471W
Old 07-05-2012, 07:26 AM   #7
RACER1530
RACER1530's Avatar
Send a message via AIM to RACER1530
Robbie,
I sent my alternator back to East Coast and had them convert to 16 volts,you will like the 16 volt deal.
Fordyce Motorsports
SC 1538 / SC 153R
RACER1530 is offline   Reply With Quote
Old 07-07-2012, 06:22 AM   #8
Robbie Welch
Thanks for that info, my alt is from East Coast. Do you remember what they charged to do that?
Old 07-07-2012, 08:12 AM   #9
drgrcr1156
Most 16V manufactures profess their batteries will not discharge below 14V (I have always been skeptical of this claim), so is a 16V alternator necessary with a singe battery setup?
Bob
Old 07-07-2012, 02:12 PM   #10
THE LEGEND
Robbie,
Call Mark Payne he can fix you up on the16V alternator too.
Chip
