Old 06-25-2012, 03:59 PM   #1
dussault.racing
Default santhuff / control arm modification question
Does anyone have a picture of what needs to be cut on 69 camaro control arms to use Santhuff shocks???
dussault.racing is offline   Reply With Quote
Old 06-25-2012, 04:29 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Default Re: santhuff / control arm modification question
I dont have a picture. I used a hole saw to cut out the entire center of the a arm then I welded in 2 new tabs to bolt the shock to. The shock needs to move outward to give enough room for the adjustment knob at the bottom of the shock. I pulled the a arms out to do the mods. I also used the bracket supplied by Santhuff for the lower mount to the a arm. It was a pretty easy install if you can weld and fabricate. you will also need a snubber so the shocks will not extend too far. Great shocks. They will absolutly control the front end bounce.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
