Old 06-18-2012, 11:12 PM   #1
gnicholson
Liked 4 Times in 3 Posts
Default titan oil pump help
i have a bbc that had 75lbs of pressure hot at 7500 rpm with a stock volume pump. because of nhra's stupid diaper rule i ended up changing pans for front steering clearance with the diaper and sending the new pan out to get the diaper made. at the same time i decided to get a titan sportsman pump rather than change pickups on my chevy pump. i had to send it back once due to insufficient pan to pump clearance. i primed the pump and checked the pressure at the time which was fine at 70 lbs. the problem now is with the engine completely warmed up and heat soaked i have 110 lbs of pressure as it revs . the bypass is either sticking or it cant deal with the volume to keep pressure at 75lbs. they were supposed to check it after it was built. the engine did it immediately also so i cant imagine a a piece of debris from the engine sticking it. any experience with these?was racing this weekend. not now huh
gnicholson is offline   Reply With Quote
