Old 06-18-2012, 01:18 PM   #1
bill dedman
Liked 6 Times in 4 Posts
Default Holley float level sight plug holes
I bought two new float bowls for my Holley 4150 double pumper and installed tham only to discover that the location of the float bowl sight plug holes is different, from the front bowl to the back one. Is this anything I need to address, or more to-the-point, why would they be at different heights? What am I missing here???
Anybody got any ideas on this?
Any information will be appreciated!
Bill
bill dedman is offline   Reply With Quote
Old 06-18-2012, 01:54 PM   #2
BlueOval Ralph
Banned
Default Re: Holley float level sight plug holes
Just use a 3/8ths drill with the bowl up side down. Seems as I remember there was a difference between the 4150 & 4500 bowls. Are the ones you got drilled and tapped on both sides of the fuel inlets? If they are they are 4500 bowls.
BlueOval Ralph is offline   Reply With Quote
Old 06-18-2012, 02:37 PM   #3
Ed Wright
Ed Wright's Avatar
Originally Posted by BlueOval Ralph View Post
Just use a 3/8ths drill with the bowl up side down. Seems as I remember there was a divergence between the 4150 & 4500 bowls. Are the ones you got drilled and tapped on both sides of the fuel inlets? If they are they are 4500 bowls.
I agree. I don't think serious racers use the sight plugs anymore. We didn't in the '70s.
Ed Wright 4156 SS/JA
Old 06-18-2012, 03:31 PM   #4
bill dedman
Ed,
I'm not a serious racer (as you know,) but neither do I want to run around with float levels maladjusted. I didn't know an alternative way to adjust them...
Thanks for the info.
Bill
Old 06-18-2012, 03:36 PM   #5
bill dedman
Yes, I had to move the inlet to the other side of the carb for the applicatiion, so I just bought two new bowls. One of the new bowls has threads on both sides of the fuel entrance. I guess that's the 4500 bowl...
Thanks for the explanation!
Bill
Old 06-18-2012, 03:54 PM   #6
Harry 6674
They are supposed to be different heights. At least thats they way Holley makes them.
I believe the secondary is higher than the primary.
Harry 6674 is offline   Reply With Quote
Old 06-19-2012, 02:17 AM   #7
bill dedman
Thanks for that bit of information! I learn SOMETHING new, every day...
Bill
Old 06-19-2012, 01:12 PM   #8
Ed Wright
Ed Wright's Avatar
I always use a 7/16" drill bit as a gauge for the primary (front) and 3/8" for the secondaries.
Old 06-20-2012, 02:18 AM   #9
bill dedman
Thanks, Ed; I am sure that's good advice! I'll follow it!!!
Bill
Old 06-20-2012, 09:25 AM   #10
BlueOval Ralph
Banned
If its a square carb like a 750 same pri & sec vent and throttle blade size I make everything same float levels air bleeds and jets same
