Old 06-14-2012, 01:23 AM   #1
jmantle
Liked 172 Times in 81 Posts
Default Ford 2150 2 barrel
Does anybody have any actual flow numbers on a 1.08 2150 carb?
jmantle is offline   Reply With Quote
Old 06-14-2012, 09:06 PM   #2
fordteacherguy
Liked 160 Times in 51 Posts
Default Re: Ford 2150 2 barrel
Jim, here is a copy from a Ford forum.
The autolite 2100 (2 Barrel) came in sizes ranging from 190 to over 400cfm. They have an engineering number cast into the body that identifies the size. There is a clock face cast into the right side of the carburetor. The carburetor size can be found right in this clock face. For example with 1.12 cast into the aluminum; the 1.12 indicates venturi size.
According to the Ford Carburetor Guide from Pony Carburetors, flow figures for the Autolite 2100 carbs are as follows:
.98 venturi = 190cfm
1.01 = 245
1.02 = 240
1.08 = 287
1.14 = 300
1.21 = 351
1.23 = 356
1.33 = 424
fordteacherguy is offline   Reply With Quote
Old 06-14-2012, 11:56 PM   #3
Rory McNeil
Brian, do you know if Ford rated their 2 barrel carbs on a different vacuum spec than the 4 barrels, like Holley did? Considering a 1.08" Autolite 4100 is rated at 480 cfm, I believe, I`m just kinda sceptical that even the biggest 2 barrel (likely from a 69-72 429 2 barrel), would be that close in size.
NHRA 6390 STK
M/S 85 Mustang
Old 06-15-2012, 12:19 AM   #4
jmantle
My computer only accepts 1 1/2" Hg or "actual flow numbers" so I was hoping someone had actual flow numbers. I tried the 40% thing to convert the 3" Hg numbers to 1 1/2" Hg but the results I got were too good.
Brian, what size carb is on Brian's Comet?
Old 06-15-2012, 12:37 AM   #5
Phillip marvetz
Phillip marvetz's Avatar
Talking Re: Ford 2150 2 barrel
It's alot smaller than the one Jason's.
2009 V/SA Record Holder
Old 06-15-2012, 09:22 PM   #6
fordteacherguy
Jim,
Brian's Comet as well as Hrenko's all have the 1.08. We nicknamed it "Wheezy" for it struggling for air! Quite the restriction on that motor.
Old 06-15-2012, 09:34 PM   #7
jmantle
Thanks Brian, that's what I needed to know. Going to Spokane?
Old 06-16-2012, 12:10 AM   #8
fordteacherguy
See you in Spokane JIm!
Old 06-16-2012, 08:55 AM   #9
BlueOval Ralph
Banned
If you dig into SAE standards there is a flow rating for card as I remeber it is 1.5 for 2V 3.0 for 4Vs and there is one for 1Vs
Ralph
BlueOval Ralph is offline   Reply With Quote
