Go Back   CLASS RACER FORUM > Class Racer Forums > Competition
Old 06-14-2012, 12:06 AM   #1
283nova
283nova's Avatar
Default what class does this fit in?
a friend of mine has a 89 s-10 blazer thathas an ls based powerplant, 325 cubic inches with twin turbos, weights 3000 with him in it, what class of comp would this fit in if any at all? i am stumped!
future superstock eliminator racer and gear banger....
283nova is offline   Reply With Quote
Old 06-15-2012, 09:50 PM   #2
Greenlight
Liked 79 Times in 22 Posts
Default Re: what class does this fit in?
There are only a few turbo classes in comp. for full bodied vehicles. Here is the one that "fits".
The info. below is cut and pasted from the rule book:
AA/AT: 5.90 or more pounds per cubic inch. Turbocharged;
V-8 only; 1,500-pound minimum
All heads must be NHRA-accepted, two valves per cylinder, OEM
casting (no billet) with OEM number cast into head.
Methanol permitted in AA/AT.
Air-to-air or water-to-air intercooler permitted on turbocharged
vehicles. Maximum ... two turbochargers...
TRANSMISSION, Automatic:Permitted in AA/AT
TRANSMISSION, Manual: Permitted in AA/AT
BODY, Full-Bodied Cars: Must have coupe, sedan, pickup truck, or convertible body
commercially available, NHRA accepted.
With a 325 cid engine the minimum weight is 1920 lbs..
The index is a 7.04 and the national record is currently at a minumum of 6.64.
Greenlight is offline   Reply With Quote
Old 07-19-2012, 01:07 AM   #3
283nova
283nova's Avatar
sorry for the late reply, thank you for the info.
