Old 06-07-2012, 08:34 PM   #1
Weekend Racer
Default rocker geometry
I am trying to use the Jim Miller rocker arm geometry on my jesel stand to put the roller in the center of the valve tip at mild lift.Once the mathematic are done this tell me to drop the stand .097.Once the stand are drop ,I check the print at mid lift. Here the problem .The print have shift well over the center line to the exhaust side .?
I am becoming crazy
Have any input on this set-up or a better way to ajust rocker arm stand geometry
thank!
Weekend Racer is offline   Reply With Quote
Old 06-07-2012, 08:52 PM   #2
Default Re: rocker geometry
I'd suggest you call T&D, and do it their way.
