Old 06-06-2012, 10:56 PM   #1
MattC
Default Advice Needed
Hello, I am new to the forum and was looking to get some advice. I am beginning to work on my late fathers big block Camaro after it has sat about 8 years. I am a plumber/ fitter by trade and have limited car mechanical experience, but I am mechanical.
The Holley fuel pump was seized and I got it working. Now I have a fountain coming from the carb vents when switched on. The floats are free so I was going to try a new regulator (even though it was free when pushing on it when I had it appart). The seat valves on the Holley carb seem free and loose.
If I get the fuel system working what should I do before firing it up? I pulled the plugs and shot PB Blaster in the cylinders and turned the motor over for 4/5 seconds to see if I could get oil pressure but no luck. I wasn't sure If I should continue without some advice. Thanks, Matt
MattC is offline   Reply With Quote
Old 06-07-2012, 10:33 AM   #2
rickseeman
rickseeman's Avatar
Liked 2 Times in 2 Posts
Default Re: Advice Needed
How long has it been sitting?
rickseeman is offline   Reply With Quote
Old 06-07-2012, 11:09 AM   #3
MattC
It hasn't been started in about 8 years.
Old 06-07-2012, 12:52 PM   #4
bobby
bobby's Avatar
Your floats could be dry rotted and soaked up fuel and made them too heavy to float. You could have a minute' piece of trash in the needles. You could have too much fuel pressure. All these really need to be addressed. Even if everything moves freely, the above mentioned could cause a problem.
Welcome to the forum. What's your location?
Next time wave all of your fingers at me.
bobby is offline   Reply With Quote
Old 06-07-2012, 12:56 PM   #5
rickseeman
rickseeman's Avatar
You know the cylinders are going to be rusty. And a lot of other things. I understand why you don't want to tear it down, Pandora's box kind of deal. After you get the fuel pressure right, if it will spark it will probably run. I would probably change the oil filter again after 30 minutes.
Old 06-07-2012, 01:49 PM   #6
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
You should pull the distributor and prelube everything, and build oil pressure. Pull the valve covers and verify that you have oil coming up to the rocker arms. Rotate the engine by hand a couple of revolutions and prelube again. That will help from dry running the engine prior to seeing if it will start.
Is there water in the radiator? Has the car been exposed to freezing temperatures?
Good luck
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 06-07-2012, 02:06 PM   #7
jmcarter
jmcarter's Avatar
Liked 3,226 Times in 981 Posts
Good advice here...after running it to full operating temp I'd definitely do a leak down. After sitting 8 years you'll be lucky to get off without tearing it down. If the leakage isn't too bad it may not be able to RPM due to weakened springs. Like Bobby, I'd be curious where you're located, you probably have a racer close by to offer some guidance.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 06-07-2012, 04:41 PM   #8
MattC
Thanks for all the advice. I got a fuel pressure gauge today and will start there. I am dreading a tear down if necessary. I am in Coeur d'Alene Idaho. I'll keep posted what I find.
Old 06-12-2012, 07:47 PM   #9
MattC
Tested fuel pressure and it was 10lbs. I ordered a rebuild kit for the regulator. We will see if she fires in a few days. I am hoping that there isn't too much damage from sitting since it was in my garage that doesn't get below 45 degrees.
Old 06-13-2012, 08:18 AM   #10
jmarkaudio
As long as it's been sitting you need to put a kit in the carb, and replace any nitrophyl floats in it.
jmarkaudio is offline   Reply With Quote
